Brief Description: Modified rudder stops for maximum rudder travel
Modified F-792 rudder stops for maximum rudder travel (35° L/R). I plan to modify the rudder stops in such a way as to accept a UHMW "bracket" that would restrict the rudder travel to the minimum value (30° L/R) and to cushion the metal-to-metal contact on hitting the stop. 5.5-6cm additional offset would be enough for 5° less travel.
