Brief Description: Drilled right bushing and rudder pedal brace
Drilled right bushing. For some reason, the transfer of the hole pattern to the stringer didn't work this time. Was off and had to make an elongated hole for the aft bolt. Not nice. Fitted the rudder pedal brace F-6118 to the firewall stiffener and drilled the holes. One hole was off, had to redrill the hole. Not pretty, but I don't see any structural problem in this area.
Elo0ngated hole in the stiffener for the bearing block
Pedal brace fitted
Cut to extranous aft part and instalöled ligthening holes
