Brief Description: Deburred and dimpled holes in right wing
Deburred all holes in the right wing ribs and rear spar. Dimpled all holes in the right lower outboard wing skin and the associated holes at the rear spar and ribs. Mis-dimpled one hole in one rib (aft) at the outboard flap hinge bracket. Installed brass bushings in the right wing flap hinge bracket.
Slightly mis-dimpled hole in right lower wing skin.
