Brief Description: Enlarged left rear aileron pushrod hole
Fitted the aileron on the left wing (with the aileron hinge brackets cleko'ed on) and enlarged the rear spar aileron pushrod pass-through. After four fittings (involving mounting the aileron hinge brackets with clekos, hanging aileron, attaching aileron pushrod to aileron and bellcrank, and then do everything in reverse for the sanding and filing). Matchdrilled flap and aileron gap fairings.
