Drilled remaining (4 outboard ribs) holes for the coax cable. Drilled with unibit to 3/8" and used SB 375-4 bushings. Started on the big hole for the wiring conduit. The pre-drilled holes are too close to the spar, can get no drill that close with the big unibit. Looked for an alternative location. Decided to use a location near the top skin aft of the first big lightning hole.
Hole with bushing for coax line
Inside view of the coax run
New location for the big (3/4") hole for wiring conduit
