Brief Description: Plugged the left HS and VS tips
Continued working on the fibreglass tips: On the right HS tip, put a layer of glass on the inside and outside of the previously glue-in foam. On the left HS tip (which I did cut straight erroneously), glued on the angled foam. On the VS tip, also glued in the foam. On the elevator tips, drilled and CS all holes for the screws and the nutplates.
