Build Log
RV-9
Manual 6-10
Glassed the inside elevator and rudder tips
Glassed the inside ridge of the elevator tips and the top rudder tip. Added a layer of extra thickness for the CS platenuts.
Glued a foam end-piece in one of the HS tips.
Next: Continue on glass fairing work.
One layer of glass fibre on the inside ridge
Other elevator tip and top rudder tip
Glued foam in place of one HS tip
RV-9 Home
872
386
