Brief Description: Rivetted Trim Servo Brackets, Started on Trimtab
Primed and rivetted the elevator cover plate and the pitch servo brackets. On the inside of the trim tab masked the areas of the foam ribs and scuffed with 150 grit aluminium oxide sandpaper. Cut the trim tab horn to size for electric trim servo installation.
Next: Cut out the rib clamp and foam ribs for the trim tab.
