Brief Description: Dimpled and CS right elevator trailing edge
Countersunk the right elevator trailing edge aluminium wegde. Produced some elongated holes - again. Dimpled the trailing edge skin, used a pneumatic squeezer. If you press the trigger very careful, the head emerges in slow motion. Very handy for "targeting" the hole if the pin (male) is on the advancing piston. Also dimpled and CS the #30 hole (see 13.04.2011) for a NAS 1097 rivet, so at least the rivet doesn't look out of place.
Next: Continue on left elevator (Want to glue both trailing edges and trim ribs at the same time - Don't know if the fuel tank sealant holds up once you start using it)
