Brief Description: Matchdrilled the rudder trailing edge
Manufactured the 84° drill guide block. Drilled the aluminium angle with the holes of the right rudder skin as a template. Clecko'ed the rudder skin back to the rudder, attached the aluminium angle to the trailing edge and match-drilled the holes. Drilled and CS'ed the counterweight. Disassembled the whole rudder.
