Brief Description: Dimpled left HS skin, CS spars and doubler
Machine countersunk the required holes in the HS rear spar and in both spar doublers. Dimpled all #40 holes in the left HS skin.
Also, the shipment from Van's arrived with the replacement AA6-187 angle for the attachment angles. Screwed up the fabrication on both last week. Fabricated new ones.
Next: repeat the process for the right HS and finish fabricating the attach angles.
