Eds Vans RV-7A Web Site
Date:  3-25-2009
Number of Hours:  0.00
Brief Description:  F-706 BH - Fab 729B angle and drill.
The 729B angle is some of that 0.063x3/4x3/4 angle that gets cut to lenth, clamped in place on the 729A bellcrank rib and matched drilled.
You know, I have this habit. when it comes to cutting parts to length. I tend to fabricate them just a bit longer then the plans say. Then after I fit the part, and see where it goes, I can decide if I need to shorten the part. Sometimes its a good idea to keep it long until after you drill it. Then adjust the length based on where your holes actually ended up. Other factors come into play that warrant that you first fabricate the part longer then the plans say. Adjust after its fitted in place. You get used to it.
Drill the angle.
Drill the angle.
Debur. Gosh, I'm hungry.
