Eds Vans RV-7A Web Site
Date:  5-28-2011
Number of Hours:  0.00
Brief Description:  Final mounting of rear VS to fuselage.
With the tie down bracket riveted on and all rear VS spar holes debured its time to put the VS back on in preparation to locate and drill the VS forward spar. Image 3 shows the single washer in between the VS rear spar and elevator stop. This single washer is on the left side and helps position the VS slightly to the left to over come p-factor. Yes.
Tie down bracket riveted on.
VS installed again with bolts.
Single washer to offset VS.
