Time for wiring. The kit does not provide you with any wiring. In fact they don’t provide and drawing, or hints either. The engine talks about the wiring of the engine The EIS talks about its wiring. Other then that your on your own. What switched do what, where to ground the battery, the ignition grounds? How to wire up the starter relay? Do I need a master? All these questions you figure out for your self. After some study it all comes together.
