Brief Description: Attaching the control surface horns and hinges.
Added all the control surface hinges and control horns. To install the hinges you must first -
1. use a soldering iron and melt away part of the Velcro gap seal. 2. using the soldering tip to expose hinge pilot hole. 3. rivet the first hole. 4. drill a second hole. 5. rivet that second hole. 6. drill the third hole.
Installing the control horns is exposing the bolt hole with the soldering iron tip.
