Brief Description: Replace and match drill 4 stringers.
I’ve decided to replace 4 stringers. I match drilled the holes that I could. The holes I can’t match drill will be matched drilled through the skins. I used the old stringers as a template for the shape at the ends and also the center cut outs.
