Edwards RV-8 Web Site
RV-8
Riveting Right Elevator
Riveted root rib to spar using squeezer. Riveted end rib and counterbalance rib assembly to spar using a combination of the squeezer and offset shank with the rivet gun. Riveted the right rudder horn to the spar and the root rib.
Elevator Horn Riveted
Counterbalance Rib Riveted to Spar
End Rib Riveted to Spar
RV-8 Home
