Riveted reinforcement plates and nutplates to spar. Riveted on and together E703 + E704. Flush riveted E705 to spar. Riveted on WD-605-1-L. Clamped left elevator skin to the table with blocksw and bent the tabs. first with a piece of 2x4 then finished it with the rivet gun and a flush rivet set. Had to trim some off the tabs with the dremel and deburred. clecoed E713 to skin and riveted the 2 rivets on each side that won't be accessable later. Loosly fit E714 and slid skeleton into place. Clecoed skin to skeleton. Riveted on most of the rivets in the skin and E713. Hailey had fun putting rivets in the holes and putting tape on them. She was learning how to use the clecoe plyers
