Clecoed electric trim servo assembly together. Had to move brackets over about 1/8 inch to have the servo line up. Clamped in place and drilled. Edge finished and debukrred holes. Machine countersinked the aft 2 hole for the servo brackets. Dimpled the remaining holes. Scuffed servo parts. cleaned with acetone. Stewars systems EkoEtch and primed with EkoPrime. Clecoed spar together and trim servo bracket.
