Dimpled holes in the leading edge skin for the counterballance. I found it easier to use a flush rivet set on low pressure with the dimple die than trying to hit it with a rubber mallet. Riveted the left aileron ribs to the counterballance. Riveted the reinforcement plates and the leading edge assembly to the spar. Clecoed the skins onto the spar.
