Drilled the holes on the bottom of both ailerons up to #30 along the spar. Removed the rear portion of both ailerons. Drilled the tab hole in counterballance to #40 then up to #30 on both. Dissassembled the left aileron. Edge finished and devinyled rivet lines on leading edge skin. Deburred all holes in the left aileron
