Cleaned the proseal that squeezed out around the fuel cap. Drilled out 1 rivet in the tip of the center rib and 8 on the end rib near the fuel cap. mostly on the bottom. Cleaned up the holes with acetone. Re riveted those holes with proseal. Covered up the shopheads
