Measured where the holes for the fuel sender should be in T-701. Clamped T-708 in place to use as a drillo guide. Drilled all the nutplate holes and marked the center hole. Cut the center hole on the drillpress with a 1.5 inch hole saw. Deburred all holes in T-701-L. Edge finished T-701-L. Deburred all holes in T-703-R end rib.
