Thomas's RV7
Date:  11-4-2019
Number of Hours:  2.20
Riveted the bottom sides of HS00005 and HS00006. Fixed a few rivets on the tip side that were under set. Riveted HS00005 and HS706 to the aft spar. Blind riveted aft spar to HS708. With the exception of bolting on the center bearing assembly the horizontal stabilizer is completed.
Changed plan page to vertical stabilizer. Took out parts for vertical stab spar
Top
Top
Bottom
Bottom
