Clamped F634R in plalce. used a piece of 187 bar as a spacer. Drilled the holes and deburred. Measuired and cut both F705J. David helped Rived the last rib on the top of the left wing and the skin overlap. Riveted about 10 rivets on the left wing top skin to spar. Drilled the wire holes in the center of F705A
