Deburred holes and edge finished HS601PPL. scuffed a spot inside that had some deep scratches. Spot primed with Duplicolor DAP1690. Dimpled all holes with drdt2 and squeezer where I could reach. Reveted HS707L to HS601PPL. Clecoed on spar assembly, HS706L and HS708L. Blind riveted HS708L to HS702L and HS707L. Riveted HS706L to HS702L. Riveted flush rivets HS601PP to HS702 and HS708 both sides on the bottom.
