Drilled out and replaced the previous 4 smileys. Finished riveting HS710, HS714 and HS00001 to HS702 spars. Riveted HS00005 to spar without HS00006 attached. Riveted on HS00006 and found a clearance problem with it touching the rivets for HS00005. Drilled out and removed HS00006. Trimmed back the flange and web. Riveted back onto the spar
