Thomas's RV7
RV7
Finished edges of HS702 cuts. Drilled relief hole and enlarged with unibit. Bent HS702 holding it with a board on the side of the table. A little at a time until I had the right angle. Attached the spar doublers and drilled the inboard holes.
RV7 Home
870
Elevator
160
Horizontal Stabilize
Vertical Stabilizer
467
