I worked on drawing up the connection from the wing section to the center (fuselage) section. I made the straps considerably larger and the bolt holes larger. As a structural engineer, I wanted to take advantage of the larger holes and bolts for significantly larger load capacity in the wood portion of the connection. Add pictures/pdf. Sheets 7 and8 in ACAD. Pdf
