I'm at the point where I need to install the wiring for different components inside the wing skeleton before I do any more work on the wing. Today I worked on installing wiring for the eventual autopilot system I will be installing.
I've decided that I'm going with the trim/servo type of autopilot system from Aircraft Automation/Levil Aviation. This system requires a trim tab on one of the ailerons and a trim tab on the elevator. I will be installing a trim tab on the aileron for the right wing.
I needed to install a wire (shielded 22 gauge x 3 wire) for power and control of the trim servo. To eliminate chafing and to protect the wire, I first installed some polyethylene tubing with an O.D. of 0.25", utilizing the front tooling holes of the rear ribs as the place to run the tubing. I enlarged the holes to accept snap bushings with an I.D. of 0.25" to support the tubing. I then ran the wire inside the tubing from the root end of the spar out to the location in the wing where the wire will eventually exit through a hole in the rear spar and then into the aileron.
