Sonex #1598 Build Log
Date:  2-20-2021
Number of Hours:  3.00
Manual Reference:  SNX-W08-01L
Brief Description:  Finished attaching parts to left main spar
I finished attaching parts to the left main spar. Some parts required bolts fit into tight fit holes and other parts were riveted to the spar. I attached the following parts:
Left Hand Tied Down Fitting (SNX-W11-10L)
Outboard Vertical Stiffener Angle (SNX-W11-11)
Left Hand Tip Web Assembly (SNX-W10-04L)
I also installed the bolts that help to attach the Lower Angle (SNX-W11-01) to the spar.
Parts cleco'd to spar and ready for final attachment.
Reaming for tight fit holes.
Bolts installed and torqued to 25 ft-lbs.
