Sonex #1598 Build Log
Date:  11-29-2020
Number of Hours:  5.00
Manual Reference:  SNX-W08
Brief Description:  Left main wing spar work
I finished prepping the spar caps and started drilling them using the main spar web as a guide. To make sure my drilled holes were straight, I used a drill bushing to help align the drill bit. It takes longer to get the holes drilled using this and the bits occaisionally jam up, causing the bit to break. However, I think this will be better in the long run and is worth the extra bits and time.
Spar spacer tools in place and ready to start drilling.
Drill bushing used to make sure my holes are straight.
Many done. Many, many more to go!
