Sonex #1598 Build Log
Date:  1-18-2015
Number of Hours:  4.00
Manual Reference:  SNX-F15
Brief Description:  Pattern construction
The next parts I'm working on are SNX-F15-01L/R, upper motor mounts and SNX-F15-02L/R, lower motor mounts. The drawings don't show any measured dimensions, so I have to make full-size patterns in order to make the parts.
I used some acrylic sheeting I had on hand to make the patterns. I prefer this to using card stock since I can more precisely form the shape of pattern with a file. This takes longer to make the pattern but it is ultimately more precise. Also, since I'm using full-sized patterns, all I need to do to make the left-hand parts is to flip the pattern over.
Acrylic sheet used to make full-sized pattern
Patterns rough-cut, ready for final shaping with file.
Finished patterns.
Finished patterns.
