Sonex #1598 Build Log
Date:  5-21-2023
Manual Reference:  SNX-W21
Brief Description:  Aileron bellcrank assemblies
I'm finally back at it working on the plane. I got the replacement parts in for the right-hand aileron bellcrank. The bushings for this assembly went in nice and snug. I pulled apart the left-hand assembly and cleaned all of the parts and re-assembled both sides, using white lithium grease to lubricate the bushings. These assemblies next get attached to the #9 ribs. Onward and upward!
Replacement parts. I already pressed the bushings in.
Resdy to up-drill the spacer block to the proper hole size.
Left/right assemblies finished and ready to attach to the ribs.
