Sonex #1598 Build Log
Date:  9-10-2022
Number of Hours:  0.50
Manual Reference:  SNX-W21
Brief Description:  Spacer blocks SNX-W21-05/08
I made the phenolic spacer blocks today for the aileron bellcranks. I copied parts of the plan and transferred those to the phenolic sheets so that I could have a guide to cut out the shape of the blocks. I rough-cut these on the bandsaw. I then cleaned up the spacer blocks using a small sanding drum chucked up into my drill press.
Outlines transferred to phenolic blocks.
Cleaning up the blocks on the drum sander.
Blocks sanded down to proper size and shape.
