Brief Description: Finished attaching parts to left main spar
I finished attaching parts to the left main spar. Some parts required bolts fit into tight fit holes and other parts were riveted to the spar. I attached the following parts:
Left Hand Tied Down Fitting (SNX-W11-10L) Outboard Vertical Stiffener Angle (SNX-W11-11) Left Hand Tip Web Assembly (SNX-W10-04L)
I also installed the bolts that help to attach the Lower Angle (SNX-W11-01) to the spar.
Parts cleco'd to spar and ready for final attachment.
