Brief Description: Spar web dimpling and prep work
I dimpled the machine screw holes on the spar web. I used the same method as for the rivet holes except I used a machine screw as the dimple die. Also, I de-burred all of the spar web pieces and cleaned them up with a Scotch-brite pad.
