Brief Description: Fixed minor set-back on main spar
I had to fix a problem with the main spar today which required me to re-make two parts. Somehow I didn't get the vertical stiffener angle (SNX-W11-09) completely plumb with the spar caps when I up-drilled the angle. This resulted in the row of holes for the rivets to angle towards one edge of the part and caused some of the holes to be too close to the edge of the angle. Also, since the placement of this angle sets where the upper stiffener angle (SNX-W11-08) goes, that angle was not placed properly, resulting in the drilled holes being off-set from where they should be. Bottom line was that I needed to re-make both parts and get them placed properly and up-drilled, which I did.
Holes on left side of part are too close too the edge, indicating that the part was not plumb.
