Sonex #1598 Build Log
Date:  8-6-2016
Number of Hours:  4.00
Manual Reference:  SNX-W23
Brief Description:  SNX-W23-02/pitot-static probe assembly
Today I made up the SNX-W23-02 probe assembly. I used the pre-made pitot/static probe from Aircraft Spruce. Mainly, I had to make up the mount plate and the tube support angles, then assemble the unit. This will be installed later when the wing is done.
Laying out the mount plate.
Drilling out a 3/4
Drilling out a 3/4" hole in the center of the plate.
The finished probe assembly.
