Brief Description: parts #SNX-T03-03, SNX-W13-02L/R & SNX-W20-02
I made parts #SNX-W13-02L/R (root rib attach angles) and one SNX-W20-02 (root rib attach angle) today. I also made the other SNX-T03-03 (attach angle). I messed up the first W13-02 part and had to re-make it. I has mis-read the plans and did not account for angling back one of the sides during cutting. Part W20-02 also took a bit of time to make. There are many pilot holes to drill and no dimensions given for where to drill them on the plans. The plans just say to pull the dimensions directly from the drawing. What this means is that none of the holes have been pre-measured. I had to do them all myself.
Opening up the angle a bit.
A perfect match!
Many pilot holes to measure. I hope I got them all right!
