Brief Description: Made part# SNX-D02-14/Hook Angle
I made the canopy hook angle (SNX-D02-14) today. Fairly straight forward part but it required quite a bit of measuring and laying out. I also used the milling machine to cut the slots in one side. I did not drill the holes for the handle, however. I am still deciding on which throttle quadrant to use and this will determine where the holes will be drilled.
