Worked on fitting axles to the fuselage. All axles will now slide into each tube on the fuselage separately, but fuselage tubes aren't perfectly aligned so still unable to fully install axles.
Also on the inside fuselage tube of the L-F rudder pedal the weld was interferring with the rudder pedal. Spent time filing the weld down so the pedal would fit. Need to check whether stress risers could be an issue since I had to make a sharp inside corner to avoid filing down into the frame tube.
