Connedted wire to elevator trim switch. Installed it onto the throttle handle. Rounted wire through the throttle handle, down the throttle arm and exited throttle quadrant at the hinge point. Used heat shrink to hold the wire on the aft side of throttle arm. Tested switch to make sure it functions properly. OK. Installed wire duct on the upper forward fuselage brace. This will be used to route all wires and tubing to the instrument panel. my buddy Aaron came over and we riveted the aft turtle deck on.
