Installed canopy latch, adjusted and cut latch to fit with a 1/4 inch gap from canopy forward frame to windscreen rear frame. Installed spring and trimmed, filed until it latches and operates smooth. Took latch apart, drilled and tapped hole for mounting outside handle. Checked fit, ok. Disassembled latch and shaped outside handle. Polished outside handle and inside latch bar to a bright shiny finish. Looks great!
