Applied sealant per plans and installed rear fuel tank baffle. Installed and riveted all but two tank mount brackets and sealed. Installed baffle to tank skin rivets. Applied sealant to fuel pickup access plate and installed on tank and sealed. I used proseal instead of the cork gasket to seal thies. I tightened the bolts for a good squeeze out but did not bottom out, to insure some sealant remained inbetween plate and rib for a good seal. All that is left is to shoot the an4 rivets on the two outer tank mount brackets and seal all rivet shopheads on baffle.
