Bird
Date:  5-16-2011
Number of Hours:  4.00
Manual Reference:  Pg.7-,6,7 Fig.7-11
Brief Description:  fuel tank end ribs and drain flange
Finished riveting the two end ribs and the second rib from the inboard end. Sealed each shop head inside also. Riveted the fuel drain flange to lower fuel tank skin and sealed the shop heads and made a small filet on the drain flange. Installed an AD6-xx sized pop rivet in outboard end rib tooling hole and sealed it inside and out.
