Bird
Date:  9-28-2011
Manual Reference:  N/A
Brief Description:  prepared to move fuselage
Cut 2x4's to length for legs. Cut board to fit through fuselage center section spar and drilled holes for legs. Prepared to move fuselage out of shop in order to remove long construction bench. Plan is to modify bench, put fuselage back in shop on short legs to enable next steps in construction.
