Riveted the outer top skin onto the skeleton today. Top skins are now completely riveted on. Dropped two plumb bobs to check for wing twist and straightness. Wing is perfect, no twist or turns. Very good. Installed the two wiring raceways in the wing and secured. Done another inspection on all rivet shop and factory heads. Had about 6 or seven rivets that had a portion of the factory heads protruding from the skin for some reason. It wasn't bad enough to warrant drilling out, so I elected to just shave them with my rivet shaver. Now all rivet look good both factory and shop heads. Today was a big step and very happy with the outcome.
