Fitted fuel tank brackets onto spar and final drilled. Fitted fuel tank baffle onto brackets and final drilled. Clecoed skin and inspected fit then match drilled tank to w423, fit is very good. Removed tank from wing spar by unbolting fuel tank brackets. Final drilled all holes in skin and ribs of the R/H fuel tank.
