Began studying dwg's for stall warning, decided to install the system. Fitted parts together on stall warning rib. Fitted rib into place on leading edge. Adjusted it until it works according to drawings. Drilled and installed nutplates on access cover flange, dimpled flange and cover. Drilled holes to final size for all access cover and flange locations.
